Re: row crop 300 transmission rear end oil capacity
Posted by pete 23 on February 28, 2013 at 10:37:31 from (74.47.40.242):
In Reply to: row crop 300 transmission rear end oil capacity posted by sclem on February 27, 2013 at 18:09:44:
Seven gal, hy-tran. The original book was printed long before HY-Tran was on the market. IH found out early that gear lube was too heavy to properly lubricate the TA over running clutch. (Ramp & rollers). They went to mixing 10 wt oil with a Torque amplifier additive until HY-tan was marketed with 560 series. The front test plug will fill from rear but takes a little longer to get up to level. The original idea of that front plug (explanation is hidden well in the operators manual) was to fill to that front plug level when the tractor was operated with front of tractor on an incline, working on a stationary pto or belt pulley job.
