Re: 400 diesel missing
Posted by D Slater on February 28, 2013 at 11:31:22 from (184.15.17.95):
In Reply to: 400 diesel missing posted by Brad clemmons on February 28, 2013 at 11:21:35:
First thing I would check is to see if the starting valve is stuck, bent or not sealing on that cylinder. See if there is compression at the spark plug hole when running on diesel.
