Re: final drives
Posted by rustcollector on February 28, 2013 at 16:27:20 from (70.196.3.151):
In Reply to: Re: final drives posted by Ontariojohn on February 27, 2013 at 17:55:45:
Unless you had the transmission cover off during the brake replace, no need to take it off now. If you did have the cover off, one of the shifting forks could be out of the sliding gear allowing the transmission to be in two gears at once. Agree with Brownie that it may be brake bands are too tight. Loosen the adjustment or just pull the pin at the connection to the pedal and try turning.
