Guess I didn't explain myself clearly. There is a notch in the shaft so the ring gear will not rub against the shaft. You have to get the ring gear out of the way to remove the shaft. Last year I had a clutch pedal rebushed but shaft was only wore a little so got by ok. If seals are leaking you can dig them out and replace with shaft in place. If you must take shaft out, you will have to at least take the right side differential support cage out so diff can be moved back a bit, and that will require considerable tear down. The diff support cage will not come out without removing the bull gear.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
