Posted by pete 23 on February 28, 2013 at 17:39:35 from (74.47.40.242):
In Reply to: 400 diesel missing posted by Brad clemmons on February 28, 2013 at 11:21:35:
The decompression valves are open when on gas. They close when switched to diesel. So, if you pull the spark plugs out, put decompression lever in diesel position,ground coil wire or unhook primary wire to coil so you don't stat a fire, hit the starter and no compression should come out of the spark plug holes. If it does, decompression valves are stuck or warped. You can get get at the top end of them valves with valve cover off. May be able to see a stuck valve through spark plug hole. Difficult though. If they are not stuck too bad you can go through hole and push them up. Then pull lever back to gas to open them, then again to diesel. Doing that several times may loosen them. Probably not though.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
