301d into a 560
Posted by john560 on February 28, 2013 at 20:07:15 from (66.115.214.185):
am putting a 301d in 560 that had a 282d. when swapping oil filter bases do you leave the oilpressure valve in the block of 301 or do you take it out,because the 282 base has the vavle in the base and if so what gasket do you use the 301 base gasket or gasket from the 282? and also i swapped oil sumps and not the pump is that ok? have the front plate switched and timing cover done its just the oil filter base trying to figure out. any info thanks.
