Re: Carb flare fitting connection leak
Posted by gene bender on March 01, 2013 at 10:15:08 from (67.55.226.151):
In Reply to: Re: Carb flare fitting connection leak posted by farmallboy15 on March 01, 2013 at 01:20:07:
Teflon tape needs to be used evry careful as little pieses seem to get into the carb. I use the correct fittings and teflon paste on the threads careful and no problems as they say the flare does the sealing.
