You say new gas line. Is it original style. If it is you need the style fitting with the ferrele attached to nut. You slip nut on line, push line as far into fitting as it will go , then tighten nut. That breaks the ferrele off nut and seals it up. If not original I have no idea what set up you have as people put on anything they can find in a hard ware store. The original style fitting with screen attached that goes into carburetor accepts the nut I described.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
