Re: F-20 Connecting Rods
Posted by Bruce Nelson on March 01, 2013 at 16:38:57 from (67.209.95.134):
In Reply to: F-20 Connecting Rods posted by Bruce Nelson on March 01, 2013 at 10:11:38:
Filed is what I meant. This causes the rod bearing to have too much crush as the shims contact the bearings and not just the rod. This is why I want to know the original diameter. If I can hone the rod to the correct diameter with the original amount of shims installed, I will have the correct bearing crush. Then I can remove shims and keep the correct bearing crush. The bearings have not been altered.
