Hydraulic Adapter for Koyker Loader on IH 2424
Posted by Daniel Weber on March 02, 2013 at 07:54:47 from (76.0.29.125):
Background - I have an external hydraulic pump bracket mounted on the front of the 2424 tractor. The adapter that bolts to front power shaft (coming out of the tractor) has a 4 bolt pattern on the flat dick portion which transitions into a collar with 7/8 internal spline. The adapter slides onto the splined external shaft of the pump. Questions - 1) does anyone know where I can one of these adapters? 2) Any reason I can"t drill a hole through collar & shaft and pin it?
