the string repair you mentioned will get you out of a bind if the flare is not seating tight enough ,just slide the nut back far enough to allow you to wrap 4 or 5 rounds of thread or small string in the same direction as the nut tightens between the flare and the nut, this acts as a shim,not the best way but will work until it can be re-flared ,doesn't work on cracked or bad flares
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
