Re: 706 no spark at points
Posted by old on March 02, 2013 at 18:48:50 from (209.86.226.34):
In Reply to: 706 no spark at points posted by Kirk Affeldt on March 02, 2013 at 18:45:29:
Put the old condenser back in. Now days it is very common to get a bad condenser. If that does not work try a screw driver at the points to see if you get spark with the screw driver. If you do the points are the type that have a coating on them so as to protect them and you need to clean them
