Re: Clutch Alignment
Posted by Janicholson on March 03, 2013 at 08:01:38 from (74.60.94.18):
In Reply to: Clutch Alignment posted by Jim Paterson on March 03, 2013 at 06:12:59:
If no shaft, look at the clutch cover. Most of them have three threaded holes on the cover between the levers. These holes can be used (with three of the six pressure plate bolts) to collapse the springs allowing the clutch disk to remain loose between the pressure plate and flywheel. this allows wiggle room and easy engine install. When bolted up, the P/Plate bolts are removed and put back where they belong.
If your clutch does not have the holes, compress the P/Plate on the bench and place 1/4" thick hex nuts (usually 3/8 or 7/16" size nuts) between the release arms and the P/Plate cover. This wedges the arms does and does the same thing as the bolts. I would use a piece of mechanics wire through the three nuts to assure they do not fall into the clutch cover when the pedal is pushed to remove them!
Jim
