Posted by The tractor vet on March 03, 2013 at 08:07:54 from (75.19.125.79):
In Reply to: No spark on points posted by William Tant on March 03, 2013 at 05:41:14:
(1) did it run BEFORE you changed points??? (2) if so then get another set of points. Will not be the first set of BAD points wright out of the box. (3) has this tractor set for any lenght of time and now it will not start?? If so then your points have gotten corroded and you may get lucky with some fine emery cloth and some electronic spray cleaner. If not then a new set of pionts OR it could be the condenser as i have had a few of them bad out of the box. If it is the old condenser warm it up and see if it will start.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
