Posted by John T on March 03, 2013 at 08:21:36 from (71.54.160.151):
In Reply to: Re: No spark on points posted by William Tant on March 03, 2013 at 07:36:15:
If the points are good and fully closing (not gapped too wide) that takes the voltage down to frame ground potential and provides a current path for coil current THAT MUST HAPPEN WHEN POINTS CLOSED TO EVER PRODUCE A SPARK WHEN THEY SHORTLY THEREFATER OPEN.
If you still have voltage on output side of coil even when points are closed, they (or distributor or its base) arent grounded or closing or conduting (via closure) to frame ground as they should
Shes NEVER gonna fire until point closure takes that point to a good frame ground so the coil conducts current AND WHEN THAT HAPPENS (closed) THE COILS OUTPUT VOLTAGE AND ON DIST SIDE POINTS TERMINAL MUST BE ZERO..........
Insure distributors base and distributor and fixed point and points mount all have a good path to frame ground...
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
