Re: No spark on points
Posted by wayne in mn on March 03, 2013 at 13:48:39 from (71.8.132.205):
In Reply to: No spark on points posted by William Tant on March 03, 2013 at 05:41:14:
Is the plastic insulator from the coil primary (6 volt) in the side of the distributor damaged or mis-aligned so the primary voltage is effectively grounded?
