It won't move at warp speed, but it shouldn't be that slow with the live pump. I have a live pump on my M with loader cylinders that look a little bigger. It is my only loader tractor and is not slow. I do everything on the farm with it that needs a loader and have never thought about needing it to be faster.
Is it lifting jumpy? I wonder if it is sucking air from a cracked supply pipe? Does it have full range of motion? Has it always done this?
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
