Posted by IH fan on March 03, 2013 at 14:58:51 from (108.220.169.138):
In Reply to: Gresen 3 Spool Valve posted by IAtractorKid on March 03, 2013 at 11:39:33:
I'd say the set-up on the left side of the valve is the system relief valve andit looks like it's adjustable, probably only within a narrow range, most likey can be varied 500-1000 psi, for example between 1000 or 1500 and 2000psi. Only way to tell for sure is to deadhead a valve, operate that valve fully one way and read a pressure guage on the inlet. If it had a pre-set relief, it would look more like a hex plug with the model # and pressure stamped in it.
3/4" or -12 should be okay for a 17 gpm pressure line, but your low pressure return line should be 1" or -16 so it doesn't have too much back pressure. Pete is right on the valve... it should have a detent set-up on a valve spool if it has a float position.
This post was edited by IH fan at 15:01:27 03/03/13 2 times.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
