GP Hansen said: (quoted from post at 18:00:55 03/03/13) The power steering is ran off the same pump. But would that effect it if you're not turning at the same time the bucket is being raised ?
Yup, the priority flow to the steering is always tapped off to the steering even if it is not turning. Same is true if the engine is idled down... the flow to the steering takes priority and if that is set at 3 gpm, the first 3 gpm goes tothe steering. There may be a little variation, but not much if it's a good priority flow divider.
This post was edited by IH fan at 15:06:25 03/03/13.
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa
... [Read Article]
Latest Ad:
[More Ads]
