Posted by realolman on March 03, 2013 at 16:12:02 from (74.98.26.30):
In Reply to: No spark on points posted by William Tant on March 03, 2013 at 13:39:40:
William Tant said: (quoted from post at 14:39:40 03/03/13) Done that and got spark so coil is good. Tractor doesn't crank
with key. Pull button to on position and then pull lever which
runs to starter and engage starter
then let the wire on the coil, bypassing the points, and touching nothing, and hook the other screw on the coil back up like it should be... to the ignition switch button...
pull the button and touch the "points bypassing" wire to the shiny metal momentarily again, and see if the wire that should go to the distributor sparks to the frame now.
If it does, there is something wrong with the points... if it doesn't, there is no voltage coming through the pulled button, from the battery.
This post was edited by realolman at 16:16:27 03/03/13 3 times.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
