Re: slow front loader on 350 utility
Posted by gene bender on March 03, 2013 at 16:25:35 from (67.55.226.151):
In Reply to: slow front loader on 350 utility posted by GP Hansen on March 03, 2013 at 13:53:24:
You dont have large rams check your filters in the hy system. As small dia as your cycls it wont take very much flow to raise them i would drain the hy system and then check where there mite be a filter and you front seal in the pump mite be shot and letting hy fluid into the crankase. Check to see if the engine is over full with oil that would be the first clue as the seal condition.
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
