Re: Hydro 86
Posted by pete 23 on March 03, 2013 at 16:28:29 from (74.47.40.242):
In Reply to: Re: Hydro 86 posted by Erik Dekeyser on March 03, 2013 at 15:59:43:
It is a place to start because you are then eleminating external problems, except in your case you want to be doubly sure the SR lever is fully moving the drive control spool when you move it side to side. There is an adjustment on that to get equal movement both ways. Some times just a loose quadrant will give you a no drive, stop drive or uneven speed control. I would check that part out first. Also, does it go normal in reverse. If it goes faster than normal the hydrostatic motor may be operating in the fast position all the time. The blue line on the quadrant is when the pump has reached it's maximum tilt for higher speed and from that point the motor starts to decrease it's tilt for more speed. A hydro is quite simple in theory, except about a thousand different things happen to them, mostly minor but sometimes hard to pin down.
