Re: slow front loader on 350 utility
Posted by FLOLDFORD on March 03, 2013 at 16:34:51 from (65.33.89.5):
In Reply to: slow front loader on 350 utility posted by GP Hansen on March 03, 2013 at 13:53:24:
My 350 is the same way. If you move the steering wheel the loader will just about stop. Looked at putting a belt driven ps pump on it but the way my loader mounts there is not a lot of room. I have to run mine about half throttle to have any hydraulic pressure or flow. I guess these system's are pretty marginal with a loader installed
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
