Re: Gresen 3 Spool Valve
Posted by Janicholson on March 03, 2013 at 18:41:43 from (74.60.94.18):
In Reply to: Gresen 3 Spool Valve posted by IAtractorKid on March 03, 2013 at 11:39:33:
If it worked on the H, it is open center. It means that the pressure remains at near zero in the supply line from the pump Because the valve is open to the return line to the reservoir. A constant circulation. A closed center system (and simi closed demand systems are more complex and will not work on an H. I think it will be fine on the 400. Jim
