Re: slow front loader on 350 utility
Posted by rumplestiltskin on March 03, 2013 at 19:16:54 from (107.216.124.112):
In Reply to: slow front loader on 350 utility posted by GP Hansen on March 03, 2013 at 13:53:24:
I have a 350U with power steering and the standard (in front of the distributor) hydraulic pump. My loader cylinders look about the same as yours, and I wouldn't say the loader is slow at all; in fact, if it were any faster I might think it a little dangerous. I suspect you have a problem somewhere...partially clogged screen, maybe?
Mark W. in MI
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
