Re: slow front loader on 350 utility
Posted by mkirsch on March 04, 2013 at 09:35:42 from (67.253.161.186):
In Reply to: slow front loader on 350 utility posted by GP Hansen on March 03, 2013 at 13:53:24:
Volume does have something to do with it. The bucket will dump a lot faster because it's only one cylinder. Probably the same story with the 3pt but I can't see in the picture how many cylinders it has.
The pump is 12GPM at wide open throttle, so it's not going to set the world on fire as far as speed goes.
10-12 seconds really isn't hugely out of line. Back in 1957, 10-12 seconds was sure a heck of a lot better than a pitchfork and wheelbarrow.
Probably wouldn't hurt to pull the screen and clean it. If you can find a tractor mechanic friend with a flow rate tester, you can see the condition of your pump. Since you're happy with the bucket and 3pt, I'd imagine the pump is in pretty good shape.
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
