A 300 uses a 9 gal pump so not a lot of extra to run a loader after power steering which as pointed out uses at least 3 gal a minute all the time. I would be interested to know what pressure is being built to raise the loader empty. No doubt those valve won't latch as most do not now days, but it should latch and stay while lifting loader if no restriction. If valve will latch without engine running it should also latch while running or excess pressure is required.
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa
... [Read Article]
Latest Ad:
[More Ads]
