Posted by Janicholson on March 04, 2013 at 16:33:54 from (74.60.94.18):
In Reply to: Farmall C wiring posted by petra79 on March 04, 2013 at 15:33:21:
The link will take you to diagrams. Assuming it is a generator (not an aluminum alternator) The discharge over night is unusual in that the amount of draw would be similar to leaving the ignition, or lights on. and not at all like having a shorted charging system. That usually smokes parts. Method: Use a test light to assure that the generator has no power connected to it with the tractor off. if so it is not the issue. Remove the cover to gain access to the electrical back of amp gauge. Test every terminal with a test light. Both terminals of the amp gauge should be hot. The kill switch (push pull) should have power at the connection to the amp gauge, but none at the ignition side with the button in. and volts at both when the switch is out. The light switch should have power going in, and when off, no power going out. If it has a 4 position light switch, the field connection should be disconnected (VR now has that responsibility). The switch should have voltage going to the lights in D and B. After some testing, get back to us with more detail. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
