Re: Farmall C wiring
Posted by petra79 on March 04, 2013 at 16:56:56 from (67.236.136.173):
In Reply to: Farmall C wiring posted by petra79 on March 04, 2013 at 15:33:21:
Thank you sir. Will try and check it out after work tomorrow providing no late jobs.
I printed out your post and the diagrahms. I do know the genny is good. Had it tested when I first got it. V-reg came off a working tractor (friends). Will let you know what I find.
Thanks
