404 distributor continued saga
Posted by RLO on March 05, 2013 at 04:20:29 from (50.33.204.141):
Thanks for all the advice on previous post 2 weeks ago. Need some more! After changing cap, rotor, & wires I figured out I was still getting spark intermittently so I replaced points & condenser. Trying to do this step by step so as to limit parts changing and chances for screw up. Looks like I did anyway! In setting the point gap the shaft turned a few times and now the shaft has quit rotating when I turn the engne over. What"s my next step? I gather the gear is shot. So I guess I pull the whole distributor? What kind of challenge am I in for..considering I started out changing the cap because the coil nub was worn flat? Thank you all again.
(from prior post JK - I"m from Deerfield originally - Lansing area now.)
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
