Re: Farmall C wiring
Posted by petra79 on March 05, 2013 at 16:24:53 from (67.236.136.173):
In Reply to: Farmall C wiring posted by Janicholson on March 05, 2013 at 07:23:30:
We're good there. - of coil to dist.
Here's what I've got. The A & F on the genny were hooked up backwards to the V-reg. Switched them.
Now looking at Dwg. 2 from your link.... dwg.of the V-reg shows connection points of Gen - -F - -BAT - -L
My V-reg has ....
Gen (hooked to A on the genny)
Bat (hooked to the ammeter)
F (hooked to F on the genny)
GRD (grounded to the frame)
No 'L' on mine.
One side of ammeter goes to starter-other side goes to BAT on v-reg, lite switch and + side of coil.
Mounted on the coil and hooked to the - dist. side is what looks like an ignition condensor???? No idea if the coil is 6v. or 12v. Been painted over.
Did not do any testing yet. Lets see what you get from this.
