Re: 404 dist 180 off?
Posted by gene bender on March 05, 2013 at 18:31:52 from (67.55.226.151):
In Reply to: 404 dist 180 off? posted by RLO on March 05, 2013 at 17:04:35:
You were told to locate the rotor the same position as is was when you removed it. Now you will need to get #1 on TDC firing that means both valves closed then you can position the rotor on #1 plug terminal on the cap and it will start.
