Re: External coil resisters
Posted by John T on March 05, 2013 at 18:49:07 from (71.54.160.151):
In Reply to: External coil resisters posted by Buddy Woodson on March 05, 2013 at 17:24:39:
Sort of in line with Bobs concern about heat dissipation and airflow, I like the metal mounting bracket attached to a good heat sink like a larger bolt etc that goes into heavy metal versus any thin screw into sheet metal etc and where air is circulating. If youre drawing 4 amps and it drops 6 volts (typical) thats 24 watts of heat that needs dissipated......I prefer they be used between the IGN switches output and the coils input....
John T
