Re: any tricks to free stuck engine????
Posted by El Toro on March 06, 2013 at 14:02:21 from (108.3.218.181):
In Reply to: any tricks to free stuck engine???? posted by *IHMMJD* on March 06, 2013 at 13:25:37:
If its a gas engine look down in the cylinders with a bore scope light. If there's a lot of rust you probably need to pull the head and oil pan and tear the engine down. If the engine has wet sleeves you may be able to drive the sleeve and pistons out. If there's no sleeves your local auto machine shop may be able to press them out. Hal
