Ben, since you have a 12 volt system you may have a resister inline from key to coil, if the coil is origional 6 volt,if it is 12 volt no resister. the resister could be open (voltage in none out). What I meant about the points was you can make the coil spark by opening and closing the points with a screwdriver- key on. The points open and close and you should see a spark when you open and close points or while cranking engine with cap off, in neutral. You have to have a 12 volt test light to check voltage from keyswitch to coil. you could check voltage to points if they are open. A bad condensor can short points to ground = no spark. You cannot check the rotor button (which you called little arm that rotates inside cap for voltage : you would need to check it for continuity with an ohmmeter. Let me know if any of this helps or if you get it running. MARK
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
