Re: H and 340
Posted by CNKS on March 06, 2013 at 17:12:50 from (216.144.104.128):
In Reply to: H and 340 posted by Ben Cleaveland on March 05, 2013 at 10:51:15:
Why? You are going to speed up the ground speed and reduce your pulling power unless you only pull light loads. You may get slightly more flotation. If that is what you want use a wider 36 inch tire, which will also increase the speed because wider tires usually have increased diameter, but not as much.
