Re: M won't crank over
Posted by Rich Cota on November 10, 2000 at 14:50:26 from (198.56.12.237):
In Reply to: M won't crank over posted by Tim M. on November 10, 2000 at 14:24:39:
Tim, it could be a bad cable,starter switch or starter. Take a cable from the hot side of the battery to the starter post and see if starter turns. If it does, the switch or a cable is bad. You can bypass the switch with a cable also to see if it is the switch.
Post A Followup
: Re: Re: M won't crank over
