Re: 404 timing better but no start.
Posted by Janicholson on March 06, 2013 at 18:38:16 from (74.60.94.18):
In Reply to: Re: 404 timing better but no start. posted by RLO on March 06, 2013 at 17:23:43:
There is a centrifugal governor in the distributor. It has weights and springs that advance the timing as the engine RPM increases. The rotor should move through a 20 to 30 degree arc. But the springs must pull it back. Take the points out, then the backing plate. The springs and weights will now be visible. I bet the springs are toast, or the shaft is way sticky on the input shaft. Jim
