stuck hubs on 650
Posted by Nathon on March 07, 2013 at 10:01:33 from (216.227.55.31):
In an effort to put new seals in the rear axles of my 650 I am trying to remove the hubs from the axle shafts. I have put heavy reinforced tubing across the face of the hub and bolted where the weights go. I am using the 1" center bolt to push on the tube. This creates much force but to no avail. I have drilled a hole vertically through the cast into the splined shaft to accept penetrating oil. I have heated the hub with a rosebud torch. And of course the sledge has been involved. Any other ideas are welcome. Thanks!
