Here is what I did on my 52 Super C. I bought it for $150. Good rear tires, bad fronts. Engine stuck, but sitting in a barn. No water in cylinders. I pulled the head and put a 50/50 mix of diesel/gasoline in each cylinder, then set it alight. Obviously, I removed the fuel tank beforehand. After doing this twice to each cylinder, rocking the tractor showed that the fan was spinning over. From there, it did not take much to get her back together and running. She still has other problems, but she runs. Also, I was able to reuse the old head gasket.
The heat and different coefficient of expansion between aluminum (piston) and iron (sleeve) works to break the bond between the two.
Now, if the cylinder had water sitting in it, it may be another story. You may get the piston to move down, but probably not up over the rust. In that case, the sleeve will have to be replaced.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
