Re: 806 Farmall Propane regulator diaphram- HELP
Posted by T K Farms on March 07, 2013 at 11:47:31 from (64.118.2.54):
In Reply to: 806 Farmall Propane regulator diaphram- HELP posted by Hand Clucth on March 06, 2013 at 17:14:48:
Try Carburetion and Turbo Systems Inc. in Shakopee, Mn. 55379. Phone 952-445-3910 or Fax @ 877-347-4334. They are the people I go to for all my propane parts. They are honest and will tell you what you can and can't get and will help you with problems or questions. If they can't help, then its unavailable, but they CAN tell you how to substitute and what! If you have problems, I do have one other outfit in Chicago, but have never used them. Good Luck!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
