Re: '49 Farmall Model C gov to carb adjust
Posted by Janicholson on March 07, 2013 at 15:47:48 from (199.17.6.160):
In Reply to: Re: '49 Farmall Model C gov to carb adjust posted by mkirsch on March 07, 2013 at 10:15:43:
If it is 1/2 inch off, someone has messed with it. Thread the rod more if it is too long, and cut off the extra. If it is too short, a new correct rod is in order.
Moving the throttle open is moving it in the direction that the rod moves when the throttle hand lever is moved from idle to fast.
When both are moved to that direction, measure and make the rod that length. Make sure it idles when the hand lever is moved to idle.
If it dies in the idle position, the idle speed (and or) mixture need attention to make it idle sweetly. Jim
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
