Posted by Bob M on March 07, 2013 at 18:12:50 from (66.195.235.242):
In Reply to: Re: 404 resistor wire posted by hrtuffenuff on March 07, 2013 at 17:56:13:
You can eliminate the resistor wire and it should work fine.
The resistor wire was used originally so a 6 volt coil could be used on a 12 volt tractor (it dropped primary voltage to the coil to 6 volts). However when the starter was engaged the resistor wire was bypassed so the coil received full battery voltage during cranking. This gives a hotter spark while cranking and thus more reliable starting - especially as plugs, points, etc became worn.
Just keep your 404 in good tune and you should have no starting problems.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
