Re: C301 out of an 806 two mystery bolts in head
Posted by pete 23 on March 07, 2013 at 18:56:22 from (74.47.40.242):
In Reply to: C301 out of an 806 two mystery bolts in head posted by Mitchel - Farmall 460 on March 07, 2013 at 15:00:35:
I should have added it is where the coil was mounted on other engine applications, like when the BD (black diamond) engine was used in trucks. You should see a flat spot on the 460 head where the bolts would be but were not used in that application. Also, if you look at a lot of the blocks you will see a casting indentation near center of block where the throttle linkage would have been run through the block when used in a truck. Just thought I would throw that in. I remember when we got our first 560 at the dealer ship, I said , they put a truck engine in her.
