If you are doing it with 12 volts, and the tractor has a starter terminal that is accessible between the starter switch and the starter motor, just turn on the key and firmly touch the jumper to that conductor. (polarity doesn't even matter, as you are just spinning the starter and the starter motor always spins in the correct direction.) This eliminates issues with exploding batteries because the tractor battery and system are not involved. Ground the other jumper near the starter motor. (this will not work with ""booster Cables"" they are too small to operate any starter motor and can only be used to charge a like voltage battery for 15 minutes with the other vehicle. Good jumpers will have #2 wire in them. Jim
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce
... [Read Article]
Latest Ad:
[More Ads]
