Re: live hyd question
Posted by Janicholson on March 07, 2013 at 20:08:01 from (74.60.94.18):
In Reply to: live hyd question posted by wls56 on March 07, 2013 at 16:42:51:
I cannot tell you about the relief. It for sure needs one. The belly pump had one. From the output of the M&W I would put a relief regulator set to about 1200PSI. I would then direct the oil to the priority valve, then the Christmas tree input, then to the reservoir drain valve (in the reservoir bottom with a T fitting) from the Christmas tree return. A return must also be used on the regulator to allow over pressure oil to be returned to the reservoir. It can T into the return line to the reservoir mentioned above. Jim
