Always hook + to + and - to - unless your jump starting a 6 volt system with 12 volts and then you should NEVER hook a 12 volt battery to the 6 volt one or it could be the last thing you ever see because the 6 volt battery can/will blow up in your face. Plus if the 6 volt battery is so low it will not spin the engine over good chance it will not have enough to run it either. If you still want to do it hook the ground side as in + or - the same and then the other side right to the starter. But check and double check that it is out of gear
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha
... [Read Article]
Latest Ad:
[More Ads]
