Re: Jump start a positive ground 6v?
Posted by SadFarmall on March 08, 2013 at 03:00:26 from (112.213.173.139):
In Reply to: Jump start a positive ground 6v? posted by Joe in CA on March 07, 2013 at 19:42:04:
Positive to positive and negative to negative is exactly right. If you connect positive to negative (batteries in series) you will set up a 12 Volt system with two 6 Volt batteries. If you make the grievous mistake of connecting a 12 Volt battery to a 6 Volt battery nothing will work out. In series, you will create an 18 Volt system. In parallel, you may well cause an explosion in the 6 Volt battery. If you have a 12 Volt tractor, which uses two 6 Volt batteries, you can start your 6 Volt machine by connecting up to ONE of the batteries on the 12 Volt tractor. No harm will result. Remember, when jump starting, always connect in Parallel! Either vehicle can be negative or positive to ground and it won't make any difference to the jump starting procedure. I have jump started a VW Beetle with the Farmall M.
SadFarmall
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
