Re: Jump start a positive ground 6v?
Posted by John T on March 08, 2013 at 05:32:48 from (66.87.4.73):
In Reply to: Jump start a positive ground 6v? posted by Joe in CA on March 07, 2013 at 19:42:04:
Heres a summary:
ALWAYS Pos to Pos Neg to Neg when jumping or charging, it dont matter which battery post happens to be tied to some huge hunk of iron as far as + to + and - to - rule is concerned...
NEVER jump a 12 volt battery direct to a 6, Ive seen them blow up
NEVER make a jump connections last connection near the battery especially around its top where explosive gasses can be present, I usually make the last connection on a good clean heavy frame member AWAY from the battery
If youre using a Neg ground vehicle to jump a Pos ground tractor (still use rule above) dont let the vehicles make contact.
Be safe, 12 vollts really makes her spin
John T
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
