Re: '49 Farmall Model C gov to carb adjust
Posted by mpbarber on March 08, 2013 at 07:28:23 from (67.142.168.26):
In Reply to: Re: '49 Farmall Model C gov to carb adjust posted by Jimmy in TN. on March 07, 2013 at 19:18:53:
Jimmy... Sounds like you have the opposite of my problem. It looks like I'm going to have to turn the yoke towards the carb.
I haven't taken the gov apart but I've read the instructions a couple of times and one of the things mentioned was making sure that the large spring was not only hooked in the correct hole on the rock shaft, there are 2, but also that it was facing the right way since apparently the hook can catch on something if it's put in "backwards".
Can you manually operate the gov from the carb side of the engine and get any control over the engine speed? That at least would tell you that the gov is not restricting the throttle movement.
Other than that, I'll defer to the other guys on here because it's clear to me that they know a lot more about this than I do.
good luck,
mike
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
